Steve89GTA
Hi guys
Roughing in kitchen plumbing (reno). Current sink is on an exterior wall, 1.5 inch abs vent coming down and feeding sink drain...from there it flows across to the center bearing wall where it joins the 4" abs pipe (about 13.5 feet across. The new island sink will replace the existing exterior wall sink. The island sink will be located between the exterior wall (current sink location) and center bearing wall (where 4" pipe is). So, how to properly vent sink...dishwasher will be in island as well.
First thought, carry existing vent in ext wall across (basement ceiling is exposed) and connect to sink drain (after trap?) with y abs fitting, continue on to 4" drain using existing pipe.
Distance from island sink to 4" pipe is around 6-7 feet or so. I've read that a 6' or less run from 4" main does not even require a vent (Canadian plumbing code) but I want to be sure of no issues and don't mind extending the existing vent line to the island as described. Let me know your thoughts and many thx in advance!
