Icemaker outlet box tight squeeze
Geoff Trostel
Massachusetts
I'm replacing my fridge soon and the new one will be wider than the current. I'm concerned about the water line getting pinched since the new fridge is 35 7/8" and the opening is 36 1/4". The icemaker outlet box is on the right side wall and I'm including pictures with the old fridge in place. As you can see there's room with the current fridge to bend the copper, but with the new one I don't think there will be enough room without pinching the line. The braided lines leave less room to bend as they have a large sleeve near the nut, so that's not an option.
Looking for ideas.
Thank you in advance!
Jadziedzic
Active Member
New Hampshire
Check your local "orange" or "blue" box store for a 3/8" right-angle brass threaded fitting with male threads on one end and female threads on the other; that will get the line to the refrigerator running vertically without any extreme bends in the line.
Geoff Trostel
Massachusetts
The icemake line is 1/4" OD
The fitting at the shutoff is 1/4" compression, not NPT
Sometimes you can spin the valve at an angle, or maybe not. I would need a better look. Perhaps some drywall out if it needs to be cut and redone.
I would consider installing on the back wall. That's a really tight fit.
Geoff Trostel
Massachusetts
No luck with that elbow at my blue box store. It was too big and the wrong thread size. May need to visit a plumbing supply co. I'm not familiar with compression elbows that have a female and male thread. It looks like I may need a 1/4" elbow, if such a part exists for compression fittings.
Geoff Trostel
Massachusetts
Just saw your post, thank you.
There is NO elbow with compression threads and a compression 90 would take more space than your bent copper tubing. The valve's shank should be soldered on so it could not be rotated.
