Sprinkler
Hi, I want to install a 1hp pump in a 60 meter (about 180 feet) water well. I have 3 questions:
1. I prefer not to use the 3 probe sensors, so can you recommend a good electronic pump protection kit so as to prevent dry running?
2. The pump outlet is 4 cm - would it be acceptable to use the same size pipe (4 cm) just for the well height - in this case about 55 meters, and to connect to the already buried pipe which I think is 2,5 cm? Or would it be necessary to use the 4 cm pipe all the way to the water tank in the attic?
3. Would it be possible to drop some kind of underwater pressure switch to say 10 meters above the pump, so that when the water level gets too near the pump, the pressure switch would turn off the pump? Thank you.
