Ivan Drobnjak
Hello all,
Long time lurker and learned a lot here but finally had to create an account in order to ask a question. I am remodeling my kitchen and just got the countertops and sink installed. The new sink is deeper than the old one and now I need to install the food disposal and drains. Please see attached picture for the setup, I have two drain entries (I think) in vertical line so I assume they are both connected to the same stack. Previously the top one was used for the sink and bottom one with the built in p-trap was unused. I assume this second one is meant as a separate drain for a dishwasher and just not used. It is not capped off either which makes me wonder about gasses.
With the new sink being deeper, the measurements are now good to use the bottom drain line (12 inches below bottom of the sink basins) so I was just thinking of capping off the top drain line? I don't need two I think because I was going to connect the dishwasher directly to the food disposal.
What makes this slightly challenging is that I need the food disposal on the left sink which is larger and the one to be used more. It is a large disposal (vertically and after installing it I will only have 2-3 inches to the bottom of the cabinet, so I want to measure and cut everything first because once I install the disposal it may be hard to get back there. Questions for using the bottom drain line:
1. There is a built in ABS p-trap, glued in right before exit there as you can see. Can I just cut the vertical pipe to where I need to connect it to the right hand sink drain opening? I plan to go food disposal on the left to right sink drain to back of the cabinet, turn left behind the water supply lines and connect to the built in p-trap after cutting the vertical piece to fit. I realize the largest disadvantage of this is that the p-trap is a bit further from the sink and I cannot disassemble it for cleaning. I thought about having a p-trap under the right sink basin on top of the built in p-trap, but I read on these forums not to have 2 p-traps in the same line due to trapped air between them and potential for clogging.
or
2. Cut off that built in p-trap on the bottom drain line close to the wall and turn the drain line immediately 90 degrees right to go behind the water supply lines and along the wall, then turn it another 90 degrees to reach the right sink basin drain and put a p-trap right under the sink drain and connect?
The second option is harder because I don't have much pipe there to work with against the wall and get that 90 degree elbow glued on properly. There may be just enough pipe, but not sure.
Any direction here is appreciated!
or
