Unless it is CI (and even there, it's not a bad idea and may still be required), the tub must be supported underneath; the ledger for the edges just keeps them from bending if you sit on them. Depending on the model and brand, it may come with a fully supported flat base, or it may only have some feet. You must read the installation instructions, and if it says it is optional to embed in mortar, you want to do that. Any tub that can flex will last much longer if you fully support the bottom.
