CanDo
Had a problem with my Fleck 5600 softener getting stuck in the "Brine rinse" phase of regen.
Took it apart. Cleaned. Greased.
Could not find any issues, so put it back together.
First regen went great, but noticed a bit of a leak at the brine tube connection (at the softener).
When taking the fitting off, the brass cracked.
With the lockdown in full force, was not able to go to a store to figure out what I needed.
Fortunately, my neighbour was throwing out an old softener. Same Fleck 5600 head.
So, grabbed my tools and walked down the street to salvage what I could off theirs.
Got the brass fitting, piston, seals and spacers and brine valve.
Compared everything with what I took out of mine. Looked identical.
Used what appeared to be the best of everything from both systems to rebuild mine.
No more leaks. Yay!
BUT....
Regen works normally still. At the end of the regen, the water level in the brine tank seems correct (about 8 inches). After a few hours, though, the brine tank fills with water to the safety float stop.
I cleaned the pickup tube with the air check valve at the bottom (does not have a float for the water level. Only the overflow safety float).
Any ideas of what is causing water to flow slowly into the brine tank after a regen?
PS... as it turned out, the original problem with getting stuck in "brine rinse" was caused by the brine valve catching on the cam. It has happened again since, so need to address that as well, but probably just by lightly sanding the cam and/or top of brine valve.
No more leaks. Yay!
BUT....
