Brown foam in brine tank
Vietjdmboi
Anaheim
Just started noticing a brown foam form at the top of my brine tank. Any insight on this and how to prevent it would be much appreciated.
Fleck 5600SXT Settings:
DF = Gal ; Units
VT = dF1b ; Downflw/, Single Backwash, black cam
CT = Fd ; Meter Delayed regen trigger
NT = 1 ; Number of tanks
C = 44 ; capacity in 1000 grains
H = 20 ; Hardness-- compensate if needed
RS = rc ; rc says use gallons vs percent
RC = 240 ; Reserve capacity gallons
DO = 30 ; Day Override (28 if no iron)
RT = 2:00 ; Regen time (default 2 AM)
BW = 5 ; Backwash (minutes)
Bd = 60 ; Brine draw minutes
RR = 5 ; Rapid Rinse minutes
BF = 9 ; Brine fill minutes
FM = ____0.7
Thank you!
How long since the brine tank was cleaned?
Clean it maybe every 2000 pounds of salt.
City water or well water?
Your notes should have either FM = t0.7 or FM = P0.7
Sorry FM=P0.7
City water.
I have not cleaned the system since installed which was Nov 23
I would not expect to need cleaning yet. Should be a long way to go.
I am guessing you use solar softener salt; a lot of people do. I don't know that would explain the brown foam with your city water, but I don't know what would explain it.
I typically use the bright and soft pellets. Should I be using the solar softener salt?
Would a replacement of all water and salt in the brine tank be the next steps?
Softener salt pellets are usually cleaner than solar.
I don't know what to suggest. If it were me, I might use a utility pump circulating brine thru a filter, and back into the tank. However I have a utility pump and a filter.
