MTKliving
DIYer... Wanted to add a wet bar drain for small sink. Will be using in-cabinet AAV (only one in house and code compliant for raleigh, nc). Not sure best spot to tie in to branch drain pipe in crawl space. There is a 3" vertical drain pipe entering crawl space nearby with ~45 degree bend before tie-in to 4" horizontal. Should I tie in to this 3" branch drain within the 45 degree section or to the 4" horizontal (harder to move). It would be easier for me to tie-in to the 3" 45 degree branch. Wye or sanitary tee? Is exact angle measurement required? Any issues with setup in pic? Thanks so much!!
