Delta 600 series shower valve repair
NameTaken2
New York
Pics show what I believe is a 600 Series Delta shower valve that's leaking by 5dpm, installed approx 1987.
Link to brochure with 600 Series schematic -see "Delta 2000 Parts Catalog" -pg 66:
https://www.deltafaucet.com/for-professionals/product-resources/catalogs--brochure
Q's:
1) Is repair with Delta renovation kit the best option? -any reason to consider replacement ($+work)?
2) Are following kits correct? Price diff $45 -which is best option?
Basic kit RP77738:
https://www.homedepot.com/p/Delta-R...and-Tub-Shower-Applications-RP77738/205166198
Complete renovation kit RP54870 -upgrades from knob to lever:
https://www.deltafaucet.com/parts/product/RP54870.html
3) Schematics for both kits don't show the RP250 adjusting ring.
RP54870 kit also doesn't show RP250 adjusting tool: is part RP250 deleted with this upgrade?
Is the adjusting ring normally undamaged after removal?
Valve is at relative's house >1Hr from big box/plumbing supply, therefore goal is to ensure correct parts and good repair plan before tear into it.
Thanks for your time!
Sylvan
Still learning
New York
Personally I would replace it with a pressure balance type and the valve body with integral stops
Also Delta is an amazing company as they guarantee their showers for life. If you contact Delta and E mail your valve and take a picture of the cartridge chances are they will ship you new parts for free
NameTaken2
New York
Sylvan, thanks for your reply-
What is the basis for your recommendation to replace with a pressure balance type and the valve body with integral stops?
Replacing the valve adds lots of work and expense, requiring opening/closing wall behind the valve and a much higher cost of new valve/plumber vs the DIY valve rebuild.
This valve works fine, therefore appreciate reasons why replacing and the related work/much higher expense was recommended as best option.
NameTaken2
New York
Terry, thanks for your recommendation of the RP54870 kit, and apparent OK for the basic RP77738 also-
Understand that pressure-balanced is a nice upgrade-
Unless rebuilding current valve is clearly a bad decision(?), then prefer to avoid the extra hours to open/close the wall and the 100's of $ extra to have a plumber upgrade this valve vs the DIY rebuild.
Therefore, unless the votes here are that upgrading is worth the extra time/expense, will use the RP54870 kit.
RP54870 kit doesn't show the RP250 adjusting ring or tool: is part RP250 deleted with this upgrade?
Is the adjusting ring normally undamaged after removal (if needed to install RP54870)?
Mad Plumber
Mad Skills
25 year old house on a well. Leaking Delta shower valve. Let the hot water run 5 mins. Drained down applied the most awesome strap wrench in the world and the nut pops right off. Its a Sloan strap wrench
Craig Allen
Don't do what this guy did!!
