CSV makes a rattle noise
Rman
Master mechanic
northern NJ
I have a CSV installed now for 7years. I’ve noticed that there is a rattle noise when pump is running. Everything works properly. 3/4 hp 10Gpm pump set at 300 ft in 320 ft well 5ft static level produces 4GPM. One thing I noticed is the valve is installed up side down. Adjustment screw is down. Pressure switch 50 on to 65 off
Is there a way to disassemble the valve in place or better to remove valve first? No sediment in water just iron and hard water
Thanks
