Designing pump system - feedback?
natgoats
Western NC
Hi, I'm getting ready to install a pump system in a new well.
Well stats: 3/4 gpm, 740 total depth, 120ft down static water level.
I think I'd like to start by installing the pump 300 ft down (with a cycle sensor or pump saver) and see what it's like living with that amount of storage. If necessary we'll go deeper/build a reservoir system.
Here are two pumps that I believe would meet my requirements. Obviously the grundfos is a lot more expensive. Does anyone have strong experiences/preferences towards or away from either? Or another pump entirely that you think would be better?
Then along with the pump, my shopping list is as follows. I'd love a second set of brains to check I haven't forgotten anything.
Threaded-to-barbed SS adaptor, SS pipe clamps, 300' of black poly pipe, 400' of 12G submersible wire, splice kit, electrical tape (to fasten wire to pipe), and well seal ( https://aquascience.net/6-x-1-abs-single-hole-submersible-well-seal-with-cable-seal ).
It is my understanding that the cycle stop valve and cycle sensor do different things so it would make sense to put both on?
It seems like y'all generally don't recommend a rope, the little plastic brackets that are meant to protect the wire from getting bumped up, or torque arrestors?
I'll be running the waterline and wire to the house through a larger pvc casing so it's less likely to get damaged and easier to pull/locate if necessary. I live in the south and will be building an insulated well house so I'm not doing a pitless.
For the plumbing inside the well house and to the (small) pressure tank and hose bib for testing could I just use PEX instead of PVC? Are there reasons I missing that make PVC a better choice?
I think that's everything.
Thanks in advance!
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
You might want a little more GPM to supply the house. I would use either the 10SQ10-290 or the 10S10-15 Grundfos or a 10GS10 Goulds. The Cycle Stop Valve will vary the flow rate down to 1 GPM to match what is being used in the house, but these pumps would let you run more than 1 shower at a time when needed. 200 PSI Poly with long barb fittings will work, and yeah don't need torque arrestor of wire stand offs. Pex is OK but use one size larger because the insert fittings reduce the flow.
The PK1A kit is all you need to control the pump and can be moved to the cistern pump if you decide to use one. The Cycle Sensor can be used to protest the well pump and another can be used to protect the booster pump from running dry.
