qtrmiler347
Could not find it in a search here.
Was at the plumbing supplier buying a new tank-to-bowl seal for my Toto Drake, and a guy recommended I sandwich the small tank holes with a rubber gasket on each side of the hole (along with nut and stainless washer to crush the rubber seals), and then use that same bolt and another set of nuts and stainless washers to bolt the tank onto the toilet. This sounds like a great idea and would reduce the chance of tank leaks or cracking in the small hole on each side of the tank since now it only needs to be tight enough to make the main tank-to-bowl gasket seal up.
Thoughts? Sounds good?
