Basement Bathroom Plumbing
Supperfly17
Ontario
Well this is what i did. The only difference from original is I added the long 45 degree angle as you can see. Does this cause an S-Trap? My pitch is perfect and I can even go even more aggressive with the pitch if needed, but i got a 1/4 inch per foot now.
file.php
Supperfly17
Ontario
I had a plumber come over this morning to give me advice and he said "In theory there is too many elbows before the vent, but in reality it will work perfectly fine. Go ahead there"
Could you run a vent line up in the wall. That vent does not individually need to go al the way to the roof, it can intercept an existing one as long as it is at least 42" above the flood line of the other things on that vent.
Basically, you need the vent to come off of a line before it turns down into the main line, and, at least in most of the USA (don't know about Canadian codes), on a 2" pipe, that vent connection should be made within 5' of the p-trap.
The way you have it now, there is no way you could run a snake through that line, and it exceeds the maximum distance to the vent to pass codes in the USA in most code definitions.
Supperfly17
Ontario
I just used one of these things and took me a bit of twisting but was able to get into the main 4" toilet pipe. Do I still need a cleanout or should i just go and cement it all in?
Supperfly17
Ontario
This is the way I have it setup now. How would you change it HJ? The distance between the vanity drain and shower trap is 65 inches
quote; as long as it is at least 42" above the flood line of the other things on that vent.
The code reads, "As long as it is 42" above the FLOOR, or 6" above the FLOOD LINE, whichever is HIGHER".
HOW can you run ABOVE the 3" line and still have the trap NOT drop down to the vent? Are you going THROUGH the 3" pipe?
Supperfly17
Ontario
I am having a hard time understanding the concept there. I am going above the 3" pipe.
How would you do it differently? Thanks again.
CountryBumkin
Active Member
Orlando, FL
Could you come off the main line to the new shower location and run a new vent line from trap arm to tie in with the existing vanity vent?
If looks like there is a wall just above the shower drain location. Can you run a new vent line through that wall, and once you get above 42" turn it to the left and connect in with the vanity vent line in the other wall (or make connection in attic space if that is possible)?
Cacher_Chick
Test, Don't Guess!
You will likely need to access the line further downstream so that the vent can come up within the wall to go through the roof or otherwise tie into the existing venting system. We cannot see the pitch and depth of the pipe there, but it appears unlikely that you would be able to connect up where the old connection was.
This is.
Supperfly17
Ontario
So would something like this work
Supperfly17
Ontario
Can I test the current setup by pouring down a few gallons of water down the toilet drain pipe and see if the p trap water from the shower drain is still there?
