American Standard has a shower kit that fits a 48" space that comes as a curved pan and a three panel wall set. I was helping my sister install one in a rental she has, replacing the aged and leaking shower that come with the modular home. Pretty crazy stuff you find in old modulars.
The completed install before the doors went in. That's cardboard laying on the pan so we wouldn't scratch it while working on it.
My brother-in-law, Omar Mardini installing some backing for the back wall panel.
Check out the flimsy shower head that we removed and tossed.
The new shower valve got PEX and copper, which was supplied by the old polybutylene piping. Those are PB by PEX Sharkbites there for the different sizing of the two pipes. The gray side of the coupling is for the PB.
A new Delta R10000-UN shower rough valve with PEX run to it. The framing is set up spaced for the valve and for gluing the panels on.
The pan drops down and needs shimming and fast setting mortar mix. Not the slow stuff, the quick setting stuff. As per my instructions from decades ago, small piles of mortar that will squish out and away to conform to the pan. Make sure you mark the walls for level before you commit do dropping and installing.
