AhToilet!
Nope I guess 2 1/8" is all that it is.Reach you are the best.
Ah I think I get it. Siphon jet is that little jet in the center bottom of bowl?Does dynamax mean the 1.28?
Hi Reach.These are new pictures? You removed the repair ring, because it was not as strong as it looked, right?
If yes to both, I would consider a Danco HydroSeat with wax beneath. Yes, it has the wax, but you can see the wax seal go in before you drop the toilet. The HydroSeat has screw holes on the legs, and it has holes more interior... use whichever works better for you.
For screws, I would be looking at stainless steel Tapcons. With those, make sure the hole is drilled deeper than the screw point will be, and blow out the debris.
Some use lead anchors. That seems like it would take more skill to get into the right place.
