4 x 3 Spigot by Hub
Hoppy
Hi. I had to remove the toilet flange ( replacing rotted subfloor and discover a
4 in. x 3 in. ABS DWV 90 Degree Spigot x Hub Closet Elbow. Do I need to replace this or can I just use a 3 inch 90 elbow?
On a toilet bend, you can use a number of fittings including a medium 3" 90. The distance between the centerline and the finished flooring will determine some of what will work there.
Hoppy
Thanks Terry! I will try fit with the 3 in 90 to make sure it fits correctly. If not, I will get the Spigot and Hub!
