I don't know how the other site rates their toilets.
Most of them have never installed a toilet.
Here's a little secret about the Toto toilets.
They use the same flush valve and same trapway design.
They only thing that changes is the style.
I've seen some ratings that vary a bit on paper, but in real life it all evens out.
The testing isn't very real world.
The real facts are that the trapways are similar and they use the same 3" flush valve, and have for over 10 years.
Any Toto with the 3" flush valve is going to work well.
All Toto toilets have Superior quality control.
Toto Vespin II CST474CEFG with SS114 Softclose seat.
This bowl was installed on a 13-1/2" rough-in using the 14" Unifit adapter.
The water shutoff can be as close as 5-1/2" to the left of center, unless it's higher off the floor, and then it can be even closer to center.
This shutoff had been replaced with a new 1/4 turn valve with brass nipple through the wall.
Installation was by James Love of Love Plumbing & Remodel 206-949-5683
In some of the older Seattle homes, the old toilets had been wall mounted tank toilets.
Those typically are 14" rough-in and need a flange repair to use standard closet bolt connections at the flange.
Everything is on the truck for that.
The Vespin comes with a standard 12" adapter or you can order a 10" or 14" adapter depending on your rough-in distance.
