Can Sharkbite products connect to yellow brass pipe
Frank lammers New Member Messages 22 Reaction score 0 Points 1 Location New York Jan 4, 2018 #1 Can Sharkbite products connect to yellow brass pipe
Reach4 Well-Known Member Messages 38,961 Reaction score 4,461 Points 113 Location IL Jan 4, 2018 #2 If the size is right on a smooth brass pipe. What is the accurately measured OD of your brass pipe? I am using logic; I don't speak from authority. Last edited: Jan 4, 2018
Sylvan Still learning Messages 2,769 Reaction score 698 Points 113 Location New York Oct 18, 2018 #3 Yellow brass had the same OD as any schedule 40, 80 or 120 pipe Yellow brass is 60% copper and 40% zinc as opposed to Red brass 85% copper 15% zinc the wall thickness is the same for schedule 40 pipe (IPS) Also TP copper has the same outside wall size as IPS
Jadnashua Retired Defense Industry Engineer xxx Messages 32,770 Reaction score 1,191 Points 113 Location New England Oct 18, 2018 #4 If the pipe's OD is the same as the equivalent copper pipe, it should work. IF not, it either won't fit in, or the O-ring won't be able to seal. YOu may need to remove the internal stiffener there for when using pex.
Sylvan Still learning Messages 2,769 Reaction score 698 Points 113 Location New York Nov 13, 2018 #5 Copper tubing is measure by OD not ID What plumbers call 1/2" is actually 5/8 EXCEPT for TP copper which has the same OD as IPS
