Whirlpool tub leaky mixer valve--help pleasssse!
Discussion in 'Shower & Bathtub Forum & Blog' started by ramesh, Sep 12, 2020.
  1. ramesh
    ramesh New Member
    Sep 12, 2020
    Cheshire
    Hello Specialists,
    I have a Kohler whirlpool tub on second floor, not used for months, and when I switch on either the hot or cold faucet, it leaks all over in the ceiling of first floor room, but no water comes in the tub It appears to me that the mixer valve is leaking as it leaks when either the hot or cold water is turned on
    Which tiles (numbered) to break to best access it (picture attached). The access panel is pretty far I think..Would be much obliged for your advise!! Cheers.
  2. Terry
    Aug 17, 2004
    Does this have a pull-out spray for the faucet? Can we get some pictures of the handles and spout so that we can look up the parts diagram on it?
    800 pixels or less for the attachments.
    Does the access panel lift out so that you can take a look inside?
    MASTERPLUMB777 likes this.
  4. Marlinman
    Marlinman In the Trades
    Dec 13, 2018
    Florida
  5. ramesh
    ramesh New Member
    Sep 12, 2020
    Cheshire
    thanks Terry. Uploaded is a picture of what it looks like.. does that help? Marlinmann has so generously shared a pdf file of all its parts
  6. ramesh
    ramesh New Member
    Sep 12, 2020
    Cheshire
  7. Terry
    Aug 17, 2004
    I'm getting dizzy just looking at the parts list. I have never seen anything like this before. I don't know how MarlinMan does it either.
  8. Marlinman
    Dec 13, 2018
    Florida
    With everything going on with this system anything would be a guess.
  9. ramesh
    ramesh New Member
    Sep 12, 2020
    Cheshire
    So which tiles do you think if I break has the best hope of getting to the problem ?
  10. Marlinman
    Dec 13, 2018
    Florida
    I would first try the access panel. With the way water travels you can hopefully pinpoint from there.
  11. ramesh
    ramesh New Member
    Sep 12, 2020
    Cheshire
    Ok guys. Found the problem after breaking through the access panel. there is a pipe where the welding has come off (picture attached)-- will have to access it from top. My question is what suggestions would you have for making an access panel door in a way that can be accessed and if I want to stick a tile so it looks homogenous-- any ideas? I had seen some magnetic kinda doors
  12. Terry
    Aug 17, 2004
    I don't know that you will need access for that there once it's been fixed and soldered.
    What you have there almost never, ever happens. At least the plumbing part will be a simple fix, and then it's just a matter of putting the tile back in a way that looks nice and like you intended to do it that way.
Similar Threads: Whirlpool leaky
Shower & Bathtub Forum & Blog Eljer LaSalle Whirlpool help! Jun 18, 2020
Shower & Bathtub Forum & Blog Moving pump on whirlpool tub? Oct 29, 2019
Shower & Bathtub Forum & Blog Whirlpool tub loose and slides around Jun 2, 2019
Shower & Bathtub Forum & Blog What size hot water tank for a 50 gallon whirlpool tub? Apr 8, 2019
Shower & Bathtub Forum & Blog AS Whirlpool Tub Install? Oct 4, 2017
