Hello folks, new member here. Very informative site and much appreciated. I have a question that I bet someone here could help me out with. I had a new well drilled in Oct of 2017. The well driller only drilled the well and a friend of mine welded on the pitless adapter and everything else. The well is a 280 drilled well. Static water level is at 24 ft. The well is drilled in besalt rock and we hit rock at 3 ft. During the drilling, at 100 ft, we were getting 1/2 gpm, same at 200’ and no changes at 280’. We figured it was a low producing well and would make it work. We did pump the well out many times to clean out the bore hole and even ran water down through the cap to clean the walls of the bore hole. There is a 6” steel casing pounded into the rock down to 25’ pr code. Ever since the first day of use we have seen moderate to heavy silt in our water. Not sure if silt is the proper word but it’s the same color as the drilling’s of the well and I really believe its rock from the borehole. Anyways, I had a big blue 1 micron filter installed to catch the debris and it works great but I have not been able to get rid of the red water totally. Some days it’s bad bad and some days it’s just tinted, but it’s never clear. In the morning when the well is full I can go the basement and open a valve on the pressure tank and run some water into a bucket and find lots of the sediment in the bucket. My theory is that because I can find this sediment in the water in the morning and at any point where the water level may be in the well, I suspect the pump is too close to the bottom. The pump is at about 270’. Another note, very recently the water turned to total crap, virtually unusable even with the filter because it was very red and collects on everything. My well buddy told me to check the wells production and now the well is producing over 4 gpm. I’ve run thousands of gallons through this well but it’s never totally cleared up in the 4 months of its use. I did learn that a well has to be developed and basically I’m doing that while using it so I expect it to be a process that could be a lengthy. Although, since I’m getting the extreme sediment, I still suspect the pump it too low in the buttom. Sorry for the lengthy post but I figure more info is better than less. Tonight, a production test revealed the well is now producing closer to 4.5 gpm. I really believe that since my static water level is only 24 ft that I could easily raise the pump up another 20 ft and have plenty of water. Any info would be greatly appreciated.
-Lenny
-Lenny
