BrandonInIdaho
Hi All,
I have 1" PEX that I need to connect a water heater to. I know there are some push to connect options for this but I am running into a length issue with those. For the cold water I need about a 24" length and about a 36" for the hot. The water heater has a 3/4" NPT which I think is pretty standard.
I am thinking of going with one of these for the valve
https://www.pexuniverse.com/1-pex-x-mpt-threaded-ball-valve-lead-free
https://www.pexuniverse.com/1-pex-threaded-brass-ball-valve-lead-free
Now here is where I get a little more unsure. I was wanting to use FALCON connecters and there are lots of options.
Option 1.
I think I could use an FF-24 (or 36). This is 3/4" FIP on both sides, so I think I would have to use a 1"NPT to 3/4"NPT nipple at the valve.
Option 2.
I use SWC1-24 (or 36). This is a 1"FIP on both sides, so I think I would have to use a 1"NPT to 3/4"NPT reducer/bushing at the hot water heater.
I like Option 2 as I think it would be a 'cleaner' looking installation and the restriction happens as close to the water heater as possible, but I am worried that I might get a leak with the bushing connection? FALCON hose is stainless, the bushing is probably brass, and the water heater is probably a galvanized pipe? Will the dissimilar materials cause a problem right at the water heater?
I think those hoses normally have a rubber seal in them that makes the connection water tight, with the reducer bushing I would have to use teflon tape from the water heater 3/4" NPT to the bushing and then the hose would seal on the bushing, will this work? Or is Option 1 the better option.... or is there a different way I should be doing it altogether?
Thanks,
Brandon
Option 1.
Option 2.
Thanks,
Brandon
