Stuart Richman
Hi,
I have a Toto Ultra max II one piece on order. The flange is in the correct location per the spec. sheet (12" CL from finished wall). But my water supply is on the floor vs. the wall. I think it will be fine, but wanted to check with others. It appears to be outside the toilet footprint (9 7/8" wide) , but the spec. sheets does not have the footprint width near the rear (it narrows some), so its hard to tell exactly. The spec. sheet does show the supply 6" from the center line of the toilet. Mine is exactly 6", so that is ok.
Thank you
Thank you
