Wall vs floor water supply for Ultra max
Maryland
Hi,
I have a Toto Ultra max II one piece on order. The flange is in the correct location per the spec. sheet (12" CL from finished wall). But my water supply is on the floor vs. the wall. I think it will be fine, but wanted to check with others. It appears to be outside the toilet footprint (9 7/8" wide) , but the spec. sheets does not have the footprint width near the rear (it narrows some), so its hard to tell exactly. The spec. sheet does show the supply 6" from the center line of the toilet. Mine is exactly 6", so that is ok.
Thank you
You could put in a better 1/4 turn ball stop valve while access is easy, and orient the lever for easier operation.
Maryland
Thank you for the replies. Since the toilet is 10" at the widest point (9 7/8"), half of that is 5". So, I'm at 6", so I should be good.
I do plan to update to ball valves...
FYI..I also reached out to Toto to confirm, they were very responsive and helpful via email.
Thank you
