Tub spout drop from mixing valve too short
DIYorBust
Active Member
Long Island, New York
If it's upside-down, hot and cold would be reversed. If it's right side up, then it sounds like you could just install a brass nipple, as shown in Terry's diagram, and then install the appropriate fittings to connect your tub spout off of that. If that didn't work, we'd need to understand more about how you installed it.
DIYorBust
Active Member
Y
No, not really. Most rough-ins are designed for possible back-to-back installations so it is in how the valve is inserted that compensates for the "reversed" inlets.
But I assume they were not planning this to be a reverse inlet situation when they selected and installed the cartridge.
HOW the cartridge is inserted determines whether the hot and cold are reversed, NOT whether the valve is inverted. I commonly invert the valve for a shower only installation. It eliminates many future problems.
FWIW, how the cartridge is installed can also help on back-to-back installations where it then makes it easier to plumb rather than crossing over the pipes so they are on the 'correct' sides on the chosen valve.
Once you have the cartridge out, you should probably be able to tell which outlet in the valve body is larger...
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
I don't know about larger and the OP still has not said what model rough-in. My guess is it is similar to the following as I mentioned before.
Tell us what model you have and post a pic of the front with the valve cartridge removed.
LLigetfa
NW Ontario, Canada
Again, all we can do is make wild ass guesses since the OP has not divulged what rough-in he used. Take a look at the following video where a different rough-in was used. On it, the third hole is at the bottom, unlike the R10000. The guy does ramble on but if you watch towards the end, he does provide a pretty good 360 degree view of the rough-in so you can see what route the water needs to take to work properly.
pooldoc
Alabama
Sorry got busy yesterday. The model is a Delta B114900. Don't have a picture as it is at my grandsons house.
LLigetfa
NW Ontario, Canada
I think that model uses the rough-in shown in the video I posted above. It only shows the word "UP" on the back of the mounting bracket which you won't see after it is installed. You can see the internal ports however by pulling the cartridge. Compare it to the pic below. I am sure you installed it upside down.
pooldoc
Alabama
Thanks I will check it out when I can get back by there. Guess if it is upside down i will get to change it now before we close the backside.
