Kohler Tub Spout with Rear Thread Install
Barbarella
North Dakota and New Mexico
I want to preface this by saying I am renovating a house in my home town, where I am only in the summer months. I have resorted to DIY because the plumber who roughed in my tub and shower plumbing is almost impossible to get hold of . This is a very small rural community and the practically no plumber competition. Furthermore, I suspect this plumber created the problem I now have. Here's why I say that:
I have a Kohler Memoirs alcove tub (installed by said plumber) and Kohler Memoirs tub spout with diverter (rear threaded type) that requires a 7/16" projection of 1/2" nipple from the finished wall for installation. The tub spout came with a brass nipple, and I assume it was to screw into a roughed -in elbow that sits inside the finished wall. Unfortunately the plumber installed a copper pipe that extended about 7 inches perpendicular to wall.
I have cut off much of this to present state as in photo, but know I will have to cut down further if I plan to use the Kohler spout. I figured all this out after installing tile over the area.
This is so frustrating --I had these fixtures before the plumber did the rough-in. and because I was unable to be there when he did the work, I had left written notes for him as to the fixtures I had, and where they were stored at my house. Despite this, he supplied and used a tub drain assembly of his own, instead of the one I had already bought, so this present situation shouldn't have surprised me.
Now, I'm looking at the prospect of soldering a very short threaded fitting to a very short stub if I want to use the very costly tub spout that I have.
I have cut down the brass nipple that came with the spout, but also have a copper fitting for this purpose. To complicate things further, on doing a dry fit, neither of the fittings seam to screw into the full length of the spout's female receptacle (they go only about half that length, or 7/32"). Since the copper fitting I purchased has same diameter and threads as the brass nipple that came with the spout , either fitting should work. I think I might have enough room to direct my torch flame into the hole in the wall where the stub is.
I have 3 questions:
1) is my assessment and plan to sweat one of these fitting accurate, and even possible without tearing out tile?
2) should I use the copper fitting, or the brass one?
3) just how much torque is required to completely screw a fitting into a tub spout's threaded receptacle?
It is possible, even likely that the plumber sweat a male adapter to the end of a copper stub out and screwed it into the drop ear 90 in the wall. Its done this way so either a screw on or compression style spout can be used. Did you try unscrewing that copper pipe? If you dont feel comfortable trying that ....then ask the plumber if thats what he did ....should be easy enough to answer in an email....
