thehausmaus
Hello --
I am new to plumbing so please excuse any incorrect terminology.
We have a tub that recently started draining slowly and now drains very slowly. I initially plunged which didn't help. I then went to use a snake and opened up the overflow. When I took out the tub stopper, I found that there was no plunger attached to the linkage and it had appeared to unscrew itself from the linkage threads (undamaged, so it didn't break off). Using a wire, we determined that the stopper appears to be just below the drain shoe. We tried using the wire and also a magnet to get the item but they did not work (item may be brass).
There is an access panel in the closet behind the tub. One idea is to loosen the slip nut to the pipe between the overflow and the t connector and hope to be able to reach the stopper. Any other thoughts or ideas? Thank you!
