Tub drain leak at gasket
MK2007
Hello - we are just wrapping up a small bath remodel. Our contractor installed a new tub and tile surround, but we discovered a very small leak under the tub at the shoe gasket. Thankfully I had him cut in a small 8x8 access panel from our bedroom so we could check for leaks. It is an acrylic American Standard Studio tub, and on the drain he said he put silicone on top of the rubber gasket under the tub before installing the drain basket itself so he is surprised it is leaking. When he is back out to fix it, should I ask him not to use silicone and just use the rubber gasket? He is guessing that the gasket slipped out of alignment when he tightened everything together. I am also worried that the silicone may be stuck on the bottom of the tub and we won’t be able to get a clean seal.
I am not sure if it’s related but when he first installed the drain and overflow his overflow was 1/4” off so he had to cut and splice in a new piece of PVC to raise the overflow tube to the right height. Could it possibly be that the drain assembly is still too tight and not providing a flush seal under the tub?
Any number of things here.
It could be that the tub is rough where the rubber seal is. It could have been squeezed to the side.
Normally I install the washer clean and only use sealant under the flange. There has been at least one time that I did use Silicone where he did
Thanks Terry. If the tub is rough, is there a remedy?
some times on fiberglas the bottom of tub does not have a good " Flat" on it for gasket to lay on. On tubs I only use putty. just my style If there is a problem I guess I would concider something else
Thanks Jeff. He’s coming back tomorrow afternoon so hopefully we’ll be good to go.
