bac
why does it look like tub drain ells are exactly 90° so have no slope? a small amount of water is visible in mine (new install). when I adjusted the drain/vent assembly so it would drain completely then the flange would not sit flat against the bottom of the tub. I'm then afraid with standing water (albeita a small amount) the coupling (where drain ell connects to tee) will leak.
wishing I had used a glue-together kit instead
