Donn2390
I have a dual flush Toto that is several years old and still works wonderfully well, but has just recently developed a problem that I can't figure out. I noticed that water continues to run from the holes around the upper rim around the bowl. It is very slight and hardly noticeable, but water is constantly running from those holes. I have no idea how long it has been happening because it is so slight you can't notice it unless you look closely. Daughter is visiting, and she brought it to my attention because she could hear it running. I'm old, give out, and half deaf, so never noticed it.
If I shut off the supply valve, it immediately stops. It doesn't appear that the tank level is dropping, so no suspected leak in that area. I left the valve closed for a while until bowl was completely dry, and as soon as I turned the supply valve back on, the water began to seep from those holes again.
I would appreciate help and suggestions.
Thank you
Thank you
