Rmelo99
Network Engineer
So I rent my old Single Family house out now. Currently to 3 college students(females)
The first floor half bathroom toilet is acting up. Slow to flush water down the bowl. I plunged and not much luck water goes down just slow. This bathroom has it's own 4" line that joins with the other vertical stack on it's way out of the house. That bathroom is fine.
The drain for the toilet is a straight shot down from the flange, takes a long sweep 90 and then runs about 15' horizontally with a generous slope before it joins the other and exits the house.
The "vent" for this toilet is on the right side of the 4" line about 4-6" below the subfloor and is 1.5" pipe that runs on the horizontal for about 10' and then hangs a turn and goes up(to the roof).
I pulled the toilet and ran the sink which dumps into this 4" pipe further down and it takes all the water. I poured about 15 buckets of hot water down through the flange and it took all that without issue. I'm fairly certain I have no blockage in the drain.
I don't know if I'm having a vent issue or toilet issue. I asked OVER AND OVER if there was any possibilty that something could have "accidentaly" fallen in. I was told 100% no way.
I reinstalled the toilet 2x and same slow to drain each time. I took the toilet out onto the deck and peaked thru the bottom and didn't see any blockage. I also reached in from the bowl and underside but didn't find anything.
I'm having deja vu to when one of my nephews dropped a comb into the toilet. That I finally found after 20mins or so of messing with a coat hanger.
My gut tells me something is stuck in the toilet trap but I'm at a loss.
Other than the sink "s-trap" that drains below the vent, nothing uses the "vent" line from this toilet.
