D
Deleted member 83859
Guest
I am replacing the old toilet in my condo with a new one. Condo was built in ’01. The previous toilet valve shutoff was soddered on to the copper pipe but wasn’t totally shutting off the water so need a new shut-off valve installed.
1st attempt:
Cut the soddered shutoff with my angle grinder & installed a Sharkbite. Turn water back on to condo but had a drip…drip..drip coming from where the copper met the insert hole of the Sharkbite. Thought maybe it wasn’t in far enough so tried everything I could to push it further & same issue.
2nd attempt
Cut off the Shark using angle grinder & tried a second Shark…same issue.
3rd attempt
Cut off Shark using actual pipe cutter – cut was very clean and even. Used plumber sandpaper to clean off the cut and ensure no burrs, etc. This time I installed a multi-turn valve like the following: https://www.homedepot.com/p/BrassCr...et-Multi-Turn-Angle-Valve-OCR19X-C1/202047058
After tightening I am finding its not very tight around the copper pipe and I can basically pull the entire valve off. Is the issue that I am not tightening tight enough? Is it possible the copper pipe is smaller than ½”?
I am literally loosing sleep over this thing
1st attempt:
2nd attempt
3rd attempt
