Verdeboy
- Messages
- 2,041
- Reaction score
- 6
- Points
- 0
The house I just moved into had low pressure on the cold side of the kitchen faucet. Turned out the cold water shut-off valve had seized up years ago in a mostly-off position. I broke it free, and you wouldn't believe all the crap that came out. The first few minutes, the water was completely rust-colored, then huge flakes of rust came out for ten minutes, and even after several days and a hundred gallons or more, the cold water still comes out with debris mixed in. I could filter it, but I don't want to ruin expensive filters.
Does low pressure cause pipes to corrode faster, or would all that corrosion have passed through a little at a time if the pressure had been higher for all those years?
