Hey guys,
I'm new here. I'm currently renovating my basement myself, and I'm at the bathroom part, I bought a dreamlike shower base and I was seeing if anyone had suggestions. I had plumbing put in the ground into a basin and ejector pump.
The problem now is the shower drain, I have to notch out the cement in order for the pan to sit flush, I currently have an oatey drain. Is there another drain available that I don't have to chisel so much out? Is it possible to lay 2x4's flat underneath to lift it up a bit, not sure how I would finish the bottom part then.
I'm just trying to dry fit everything for now then I'll be doing a mortar bed.
It's not letting me post pictures on here as the files are too big
![ghynes-01.jpg](https://terrylove.com/images/pb/ghynes-01.jpg)
