Schedule 30 to 40 coupling
Gansevoort, NY
I'm replacing a rotten subfloor and toilet flange for a customer. Was going smoothly until I noticed that their piping is 3" Schedule 30 and all my new pieces are Schedule 40. Can somebody please recommend a coupling that will work to join these? Do they even make them? I had found a bushing to join them since the ID of both is the same, but thought using a coupling on the outside (less obstruction in the pipe even though it's minimal) would be preferred.
Live and learn I never heard of schedule 30 used for venting , or soil or waste lines
Charlotte's catalog only shows it in 3" pipe with an OD of 3.25". So I infer the hub OD is 3.5" and the advantage is that it fits in a 2x4 wall.
Cheers, Wayne
your not joining cast iron to plastic right? because 3 or 4 inch plastic is noticeably bigger than casiron and would take a cast iron to plastic adapter band. never seen sch 30 either
Yeah, that was just the first link I found, that should give you the standard terminology to search for. Hopefully you can find someone to ship it to you. Sometimes it helps to looks up a particular manufacturer's part number (Charlotte, or Genoa, or Spears, or maybe Nibco) and then search for the part number.
Cheers, Wayne
