Area-wise, 39% bigger.Really? PVC is almost 20% bigger than PEX?
No, but you can assume you should not use PB (polybutylene ) pipe, especially with city water. You are not going to use lead pipe either.Can I assume that PB has a similar id to PEX?
A duplex I wouldn't be going smaller than 1 inch . I'm guessing frost is no issue? I'd also sleeve it under the asphalt
Why would you not be thinking of putting 1 inch PEX through 1-1/4 PVC? In some areas, copper would need to be type L and would probably be soft copper. Wasn't the former copper soft copper? Anyway, I suspect that will not be attractive to you when you price it.
Polyethylene pipe (other than PEX) could be very attractive, but it needs to be transitioned to something else outside of the living space. Silly rule IMO, but rule it is.
Jeff, I don't think he can afford the 1" line, that's why he's trying to get the plumbers here to okay his idea. This guy is on a really tight budget.
(snip)
No one has recommended 3/4 but might be good enough .
You did mention PB, but I guess you didn't say you were considered using it. Was that because that material had been in place there at some time in the past? I leapt to conclusion that you were considering it, and I attempted some satire by bringing up lead.Well I have never mentioned using PB or lead so I'm not sure where that's coming from.
Common 3/4 PB is "sdr 11" and ID would be about 0.715. Pex today is SDR 9. OD is 0.875 for both.
SDR 11 means the wall thickness is 1/11 the OD.
Pressure drops add, rather than being limited by the size of the smallest element.I guess that would also mean that I'd want to start with a fresh connection to the meter and eliminate the short run of original 3/4 copper that's coming off the meter now.
