Replacing Back Outlet Toilet but mismatched flange
JoelChan
Mississauga, Ontario
Hi all,
First-time poster and never installed a toilet before so apologies if I'm using the wrong terminology. I am trying to replace an old American Standard toilet (4049-69) with a Gerber Viper GWS20022. The American Standard toilet has a flange hole ~3 inches while the Gerber Viper has a flange hole of 1 11/16 inches according to the specs. I think the vertical rough-in 4 1/4" in should be ok and the back part of the toilet (pictured below) seems to match in measurements so the only issue is the flange hole. Is this still possible to install? Any recommendations on how to address the big difference in hole size or do I need to return and find a better matching toilet?
Thanks for any help you can provide!
Joel
JoelChan
Thank you for the confirmation! I had one follow-up after checking. This Gerber toilet will be replacing an American Standard toilet. The bolts for the original American Standard toilet in place are 4" vs. the Gerber toilet at 4.25" for the rough-in height. Will this cause any issues?
John Gayewski
Iowa
Hard to say. Losing 1/4" below the toilet should be ok but they can end up very close to touching the floor. If you have a cut sheet of the toilet you should be able to see the dimension you'll need to verify there will be room.
