I am getting charged almost $50mo for a rented water heater that is installed in a home I recently bought. I have a new 12 gal, as that hopefully will be enough for 1 person. The problem is the pipes are different setup (see pic), the rented tank has only the hot on the top, and then some weird plumbing down the side. The new 12gal is the basic setup I've seen before, hot and cold on the bottom. So what is the best/easiest way to do this? Should I just drain, and cut the pipes (where?) to the tank, then use quick connect hosing to rerun the cold in and hot out? What is thatvalve in pic aaa with the grey handle? will the rental tank people want that back? thanks for any replies, I have no money to hire someone but am pretty handy with repairs.
https://ibb.co/kL5Kta
