Remove water ring on toilet with CEFIONTECT finish.
Maryland
Hi,
I have a Toto Ultramax II toilet with the CEFIONTECT finish. I've been gone for 2 months and now have a water ring in the bowl. I'm looking for suggestions how to remov the ring without being harsh on the bowl surface.
Thank you
vinegar , CLR maybe is the finish particularly weak? I have a 22 year old TOTO that is stubborn I think the china been damaged because mine builds back up in a week if not scrubbed very often we got a house cleaner she got them spottles we asked her how she had a pumice boy did I cringe but it sure worked she says she barely rubbed it.
I think mine got damaged years ago because I never had problem before or saw homes that get the ring that are regularly cleaned. I'm sure its etched now
James Henry
Billings, Montana.
I'd call Toto and get their suggestions. While an acid might clean it off, it might also damage the finish.
I had a brand new Toto installed last year thought I noticed a bit of rust in bowl ignored it customer told me about it few days later after about a week total I dropped by and deep in bowl appeared rust I hit it with a brush and nothing. Later called supply house and just a counterman told me bring it back or try CLR So I went back and pushed some water down to lower the water in bowl and it came off like nothing with the CLR and Scotch Brite green plastic.
I'm not recommending the aggressive acid or pumice just saying its a chance that worked out pretty good.
Maryland
Hi, Finally heard back from Toto and this is what they said
"For stubbon hard water stains, we recommend soaking the stain for 30-60 miutes with CLR cleaner, and scrubbing with a plastic toilet brush."
Thanks for the input.
Let us know how it comes out.
Soaking is a hard thing to do at the waterline. I think you would drop the level of the water in the bowl, and saturate pads/wads of toilet paper as a plaster over the ring.
If the ring has a lot of silica, note that CLR will not dissolve silica.
If you cannot get results chemically, I would move on to the pumice despite the warnings. You could replace the bowl.
NKaufman
USA
Toto mentions on their website - https://www.totousa.com/product-faqs
"It takes a slightly acidic cleaner like vinegar or a lime dissolving cleaner to remove the minerals. Neither of these cleaners will harm the CEFIONTECT finish."
Is CLR what Toto means by lime dissolving cleaner?
Rather than buying something specific, you might first try just using some plain vinegar which you probably have in your pantry.
Lime away , CLR or vinegar whatever you have just don't go crazy on it and flush with water
Tuttles Revenge
The cleaning staff we had a while back used to dump some sort of cleaning agent in the toilets and urinals then walk away for the weekend.. whatever it was ended up damaging the finishes in the TOTO toilet and urinal and bleached the vinyl floor.
