Kevinjm4
I glued two pieces together (ABS and medium cement Oatey blue and white can) and quickly removed it before it set because I made a mistake in my measurement. 30 minutes later I used that same fitting and put a fresh piece of ABS into it - as you normally would - glue on the pipe and fresh glue on the fitting again. Is this ok or should I cut it out?
I’ve seen lots of guys “saving” fittings like this on YouTube. But it doesn’t seem right because the glue basically melts the ABS right? But does it re-melt dried glue? Also, I didn’t sand anything or rough up the dried glue or anything like that
