thenextdon13
Hello-
If i have read everything correctly, including posts on this forum and 'helpful hints' by Bert Polk (noted by Terry Here), the Sani-T is only to be used when going from trap-arm to vertical drain pipe.
Where a horizontal branch joins a vertical branch, a combination Wye -1/8 bend should be used.
I'm working on a house I purchased that appears to use a double sani-t to join quantity 2x 1 1/2" galvanized to the 4" main. Directly above the main is the 4" closet arm and a 4" vent stack for the toilet.
Attached is a picture:
Yes, I know that the installation of the closet arm hacking up the floor joist is _really_ bad.
I have a few questions about the tie ins to the main:
1. Is this improper use of this double tee?
2. Is a combination wye - 1/8 bend the 'correct' fixture to use in this location?
3. There is very little vertical space between the joists and where the horizontal main is. This means that if I were to retrofit with a combination wye - 1/8 bend, I don't think there would be sufficient pipe grade on the new 2" horizontal lines. In addition I would like to fix up that closet arm so it doesn't have the joist all hacked up. So- is there such a thing as a fitting that does 3" sani-t with 2" combination wye - 1/8 bend into a 3" or 4" stack?
On another note;
If i cannot fix the drain properly, I would like to tie 2" into the main. Would this tee appear to accept 2" with the proper donut? The I/D of the Tee appears to be about 2 7/8", while the O/D of 2" abs appears to be about 2 3/8"
Many thanks for any insight that someone can provide
On another note;
