Qest polybutylene replacement
Dylan
La Mesa, California
We've had leaks and burst pipes and the plumber has suggested replacing the Qest polybutylene pipes. PEX would be less expensive less labor and material cost but we prefer the idea of copper. Plumber can do either. For chlorinated and acidic municipal water would type M copper resist corrosion? Or is PEX better?
Plumber said no residential uses Type K copper or 316 stainless that is only for industrial.
Between K and M is L. L is commonly used in some areas, and M would not be allowed for the potable water.
How acidic-- just curious? https://www.sandiego.gov/sites/default/files/water_quality_report_2018_final.pdf does not show acidic water.
There are two common corrosivity indexes. pH is one of the factors, but there are others. A water softener will increase corrosivity. Sometimes a polyphosphate is injected to make water of lower pH to be less corrosive. Also pH can be raised. Injecting "soda ash" in a controlled way raises pH without increasing hardness.
I would go with the PEX and use "EP" (engineered plastic) fittings. Avoid the active pH treatments. I am not a plumber.
John Gayewski
Iowa
Use L copper. It'll last just fine. M is thinner. K is used underground when soft copper isn't practical.
Tuttles Revenge
Any type of copper is fine for residential applications. Type L is just a bit thicker walled.
We normally install PEX for our repipes because it is less expensive to install and from my experience is less prone to installer error than copper installations... unless using ProPress which is what All of our copper installations are now. Any professional should be able to install either with no problems tho, so the choice is yours to make.
