I have an older shallow well pump that i winterize every year. Part of the area where the drain plug screws in has rusted off so I attempted to install a needle valve so i wouldn't have to remove it every year. But while screwing in the needle valve it started going sideways so maybe the threads were not the same as the plug. The drain plug would not screw in nicely afterwards but I was finally able to get it to go in a bit but still not as far as i would like.
Should try to use a tap to clean up the threads or is replacing the pump the better option?
