Theonecloned
Hey guys. I'm hoping a shallow well expert can help me out with an issue with a new well.
About 6 months ago I drove a new shallow well for my mother. I think my first mistake was going to the local fleet store to buy the 1-1/4 galvanized pipe. Probably not the highest quality pipe in town. The threads on one of the pipes got destroyed as I was driving it. I had to cut new threads in one of the pipes before adding another section. I couldn't cut the pipe off with a pipe cutter because of the tight quarters so I used a grinder with a metal cutting blade. Before cutting the pipe I stuffed a rag in it to stop the sparks and shavings from dropping to the sand point. After cutting the new threads I cleaned out the end and pulled the rag out and continued on.
The rest of the diving went good and I got the new pump plumbed in and it was working great. A couple weeks later is when the rust problem started. I checked the whole house filter and I could see specks of rust on the filter. I keep an eye on the filter and have been changing it every few days depending on how rusting the water is getting.
Iron is not really an issue in my area so I am assuming some of the shavings from cutting new threads made their way down the pipe.
Is there a way to clean the pipe out or am I going to have to get a new sand point and pipe and do the whole thing over?
What are my options? What other information do you need to assist me?
