trez63
Hi all,
I live on a hill in Southern California and the highest my city pressure gets is 55. The shower valves on the 2nd floor really need more pressure (They're brand new Brizo/Delta valves limited to CA limits). Even with CA limits these valves are not getting enough pressure so the water basically just pours out and doesn't push out.
All the neighbors are experiencing basically the same issue and they mostly have installed booster pumps.
I'm working with a plumber who is recommending I install a Grundfos Scala2 or MQ3-45 pumps.
The reviews I read on Scala2 frighten me because they seem to break down and leak within about a year.
The Grundfos CMBE 1-44 seems more robust but that's a lot more pricey.
Does anyone have a recommendation on a pump that can boost my 55psi to about 80psi? My budget is right around $1000 for the device. Ideally the pump will be an all-encompassing device without the need to install additional items to get the pressure up and steady.
Please note that this will be used to boost city pressure and not a well.
Thank you!
Thank you!
