Hi,
I just put an order in for a cycle stop valve but I want to double check my installation to make sure I'm doing it right.
Question 1: Is my pressure switch and valve settings appropriate for my house to get good consistent pressure throughout?
PK1A-LT Pside-Kick Pressure Tank Kit
Pressure Switch: 50/70 PSI
Valve Setting: 60 PSI
Well Pump Type: Submersed, ~100ft from house. 1/2hp
Pressure Tank: Amtrol WX-251, 62 gallon set to 47PSI
Well Entrance: ~5 feet below ground level, basement entrance.
Stories: 2 @ 9ft ceilings
Loss factors:
- Farthest bathroom from well entrance is approximately ~100ft horizontal, ~20ft vertical
- 3x Big Blue sediment pre-filters, 1 nitrate removal tank, 1 softener tank (rated 75PSI max)
- 3/4" copper trunks with 1/2" branches
Question 2: I've seen several installations. The manufacture shows the kits with the pressure tank attached via the bottom, but several posts have it attached after the fact. Do they function the same way? Are there any differences between installing a 3/4" pipe down to the floor and into the Amtrol vs bringing the CSV down to the floor and installing the Amtrak in line to the 1" NPT outlet?
Manufacture:
In Line:
Loss factors:
Manufacture:
In Line:
