I didn't see this reply earlier. Thanks for the info.Yes that looks like a bleeder orifice, so remove it and plug the hole to use a diaphragm style tank.
Sounds like you are on the right path. It is possible that the old o-ring was lubricated with petroleum jelly. That can cause o-rings to swell up and otherwise deteriorate.I just tried putting the old o-ring back on and it has stretched and is too big now.
Maybe the o-rings the plumber had are the right size. We just compared size to old o-ring.
In. The duration is limited, so there is not significant action against the pitless etc. You wash the casing and stuff with clean water.To sanitize the well, does the spool have to be out? There isn't much space to get anything down there. I wouldn't think it would be good to get bleach or chlorine on outside of the spool.
Is there any chance I could use Dow Corning DC4 instead of the Molykote 111. I already have that.Don't follow the petroleum jelly part of the directions! I would get that Molykote 111 on order, if you have not done so.
I am not sure. Here is some stuff to read. https://www.fmv.se/FTP/M7789-000193/datablad/M0729-3010XX_DowCorning_4.pdf saysIs there any chance I could use Dow Corning DC4 instead of the Molykote 111. I already have that.
I just went back over to the plumber and got the NC15 o-rings. Cost $15 each. The guy that actually installs them was there and said it is the right o-ring.
He said to use steel pipe and not plastic when putting it back in. After reading a lot of stuff here I thought poly pipe was the best thing to use and have a roll of 160 psi 1" on order. Will I be ok using that or should I consider using steel?
Not familiar with the in well control with bayonet you speak of. What youre saying makes sense....I guess i never thought about it too much...just know ive had a little trouble with light pump assemblies in past. All tbe baker industrial series units include pretty heavy duty hold down features ...must be for a reason.I would have thought with the pressure coming in between two o-rings that the pressure would equalize and it would not try to lift out? I was thinking it works the same way as a Baker In Well control with the bayonet attachment?
