Looks salvageable to me.....at least worth a try before digging. Wire brush it really well and put on some new o rings see what happens. Those things are pretty resilient....looks like a baker 4 x 2 with chech valve on the spool to me. Was it leaking before you pulled it?
For the new O-rings. If you can ID the unit, you could get those from the maker. If not, you can measure and order by size.
To help the ID, maybe take a picture of the part that sticks out of the ground, and another like you did except show the other side, if it looks different on the other side.
Look for a name cast into the spool (what you show) and the part that sticks up.
It would not work without the bottom oring...they frequently come off with lifting a spool that has been in a long time.I wire brushed it for a while. Was almost 1/4" thick in spots. The door thing was stuck pretty good. Moves easier now but not closing itself. I think I can probably get it freed up with some penetrating oil.
Here are some more pics. https://photos.app.goo.gl/Zn6FCCWYoXmNShs42
Yes....in that situation you still need a check at the top bleeder. I suspect in this case the pitless.serves as the check, the bleeder he described let's in the air and the water must drain back through the pump...unlesa there was another inline bleeder he didn't mention.Some installers will put two bleeders in the drop pipe separated by some distance. The bottom one bleeds out water and the top one lets in air.
You first asked about the tank less than 3 hours ago in #13, so that is not really into dribble mode.We are getting the info in dribbles and drabs so anyone's guess.
