bleeder valves and weep holes
Slugboy6000
Ontario
Hello, I'm looking for a way to drain my plumbing back into my well.
It's a simple setup where I'd like to manually control my submersible well pump so that I can fill an open tank with water in freezing temps and let the plumbing drain itself between uses. I'm assuming that the bleeder type valves used in drain-back systems don't work without pressure and wonder if instead a weep hole in the drop pipe would be appropriate in this situation?
My pitless adapter is only 12" below grade due to bedrock, the supply line is insulated and the outlet emerges 8' away into an uninsulated shed.
Thanks
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
If you constrict the discharge at the top a little or set the bleeder deep enough, then the pressure at the bleeder should get high enough to close the bleeder. Friction loss between the bleeder and the discharge alone would probably be enough for it to close.
Slugboy6000
Ontario
That's great, thank you very much LL.
With a 4' frost level, I think my only other question would be how deep a drain-back / bleeder valve should be to avoid freezing.
I really don't know what the temperature is like inside of a 20' steel well casing buried in limestone in the dead of winter.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Heat from the earth will rise in the well casing. Usually pipe in the casing will not freeze. Installing a bleeder orifice too deep will keep it from opening. Just a pound or two will keep it closed, so you don't need a pressurized system to make it work. I would set a brass bleeder about 5' deep and no deeper than 10'.
LLigetfa
NW Ontario, Canada
Some bleeders spec no more than 10 PSI to open and even those may be special order with others requiring less pressure. The pressure needed to close one is not the same as what is needed to open one as flow is a factor. That said, if one opens at a higher pressure, it stands to reason that it might also need a higher pressure to close so I would design the system with some constriction depending on the depth and GPM of flow.
Slugboy6000
Ontario
Lots to learn here, I appreciate the tips.
I do want to constrict the flow down to what will likely be a short length of potable garden hose. Unrestricted flow from my pump is too violent for my needs.
I can't find pressure specs for the two brass bleeders that I've been able to find so far (Boshart BOB07NL & Merrill BBONL75), but I should be sitting at around 4 psi (9' of head) when the pump is off.
I'll keep looking.
Slugboy6000
Ontario
Time has flown, but it's time to get a bleeder orifice into my well. A couple of questions have popped up.
With my submersible pump set at 85', should I be using extra long barbed fittings and triple screw clamps to insert a tee into my 1" poly well pipe?
I'm uncertain about mixing brass and bronze and I don't know which to use. To make things worse, some fittings are falsely advertised as bronze. My bleeder will be brass.
Slugboy6000
Ontario
Here's a picture of my situation so far, manual pump switch on the wall next to my outlet.
For your drain back valve, or weep hole, to work properly, you would want something to admit air up top. If there is no valve up top, and the output of the pipe is above the level water in the cistern, then that would be no problem. If the input to the tank is below the water level, you would add a check valve and snifter valve.
Slugboy6000
Ontario
The manufacturer specs one clamp for the aforementioned insert and 2 to 3 clamps for their extra long insert fittings. I'll try to dig up some more info.
When you put your two clamps in place for each barb, have the worm gears on opposite sides of the pipe. For the usual stainless steel clamps, torque the screws to 5 ft-lb (60 inch-pounds).
