Peerless shower, Help Please, shower valve handle stuck, trying to replace cartridge
Jeff Boshet
California
The trim says this is a peerless valve, but it does not have the set screw on the side of the handle, it has the screw directly in the end of the handle which I removed.
I am unable to remove the handle to get to the cartridge...
Helllllllp.... please...
Jeff Boshet
California
Do I need a puller device to pull it off if it is corroded in place?
I think I'll need to go to the hardware store tomorrow to buy a shower handle puller.
I think it is simply corroded in place
Jeff Boshet
California
The puller did the trick. It was simply corroded in place.
I just left you another small tip in your tip jar for your kind help :0)
