newmexmike
Franklin Subdrive 150 failed (probably lightning transient) with short circuit - fault 6. Disconnected motor and same fault at startup every time. Removed drive and inspected - but no evidence of damage (like Fault 5 code). TS guide says 'replace drive'. Drives a 1.5 hp pump-3/4 hp Franklin motor (or so I'm told until driller gets back with details). Replace Subdrive with another more reasonable VFD or phase convertor? Driller seems to think not - Terry's forum is about the only discourse that delves into this. What's so special about Subdrive - that there's no affordable replacement system - without dealing with 3-phase sub pump/motor setup in casing? Sorta seems like a insidious scheme when well is installed - to save bucks on parts (pump/motor sizing and cabling) - to charge in labor. Could be I'm just inna funk because another 2 grand Subdrive is galling me at the moment. Seems this has been a previous topic - but without resolution - that I've been able to find. Sure would appreciate more insight. Well system just fills 15-20% of slightly uphill 2500 gal tank - every few days - which gravity flows to Grunfos booster inside of house (~100 ft away) - which provides water on demand. Onna bummer. Thanks much for any replies - or a referral to any other solution!!
